What you need is a proper software to analyze the digital stream, a capturing device in case we work in the digital domain and the good ADC in case of the analog data. And the weak point is a software. But it does not mean that only FFT analysis software for static test sounds is available. There are also packages like DeltaWave which allows to compare on the different level including the time domain, for example.Note I said "typical bench measurements".
Of course it is measureable with the right equipment. But very few of the analysts doing these measurements has equipment to measure in that time domain.
