Help
sceavis
I have a Wiim Pro looking to change things up .I am thinking of getting a vibelink to add with the pro but this issue is that I have a turntable as well and want to add a tube preamp into the chain to get that sound with the wiim .Am i better off kepping the pro and go rca from the pro into the pre amp then out to the Vibelink then run the turntable to the RCA into the Vibelink .Or should I get a ulta and ditch the pro and use the phono of the ulta then rca out to the tube pre into the vibelink .I know this is confusing but hoping somebody can help here .Thanks for your time
What tube amp are you considering (and for what reason)? Does it have a built-in phono pre-amp?
If you want to useWiiM's EQ or RoomFit for your turntable, too, then any phono pre-amp must sit inside (WiiM Ultra) or in front of the WiiM device.
Ayima T20 I do have a phono preamp now canjust run a rca if needed and it does not have to be part of the tube .I am trying to warm up the sound from the typical digital sound.I am chooisng the T20 beause it's a real tube pre vs the buffer hope this helps
