Witterings
Senior Member
- Nov 1, 2022
If I'm using the RCA input on a Pro or Pro Plus for lets call it "The 1st Device" device and then using the Optical out from the Pro or Pro Plus into say a Vibelink.
I'm guessing the fact the 1st device has already converted from Digital to Analogue will be ignored (as opposed to passed through), it'll be converted back to digital by the Pro / Pro Plus, then fed out as a digital signal to the Vibelink who's DAC will do the conversion?
If this is correct, might I be better off just using a digital out from the 1st device into the Pro / Pro Plus avoiding the 1st and the 2nd conversion and it'll just get passed straight through to the Vibelink which will then become the only conversion?
Real shame the Vibelink hasn't got auto input sensor the same as the streamers, I'm using that on one of my setups and works really well.
