How do I connect RSL 10E SUB to the Wiim Amp Pro?
echen818
Hey everyone,
I am super new to this space and finally pulled the trigger for the Wiim Amp Pro. Question I had was how do you connect a RSL 10E sub to the amp? From what I am seeing the sub does not have a sub in/out line?
Appreciate the help!
Hey everyone,
If you connect the WiiM sub out to the 10E LFE input and adjust the sub dial according to the manual, you should be fine.
Hey everyone,
Use the LFE channel. I got the RSL 10s mkii. That’s how I hooked mine up
I have the Ultra forgot to put that in. Worked like a charm. RSL makes killer subs
Could you please explain to the OP which position you set the dial knobs for Sub volume, phase, and crossover?
Thanks. 🤗
...It is a pity that RSL subs are not readily available in my country..😢
Make sense! Thank you. How do you like that sub?
Absolutely mind blowing. I had have Wharfdale Denton 85’th anniversary bookshelves speakers. Which are fantastic. But adding the RSL sub to them. Game changer. Made my system sing. Hard to put into words. But I’ll say this. I’ve but dozens of speakers over the years. The RSL is the best audio purchase I’ve ever made.
When using the LFE input make sure to set the "low pass crossover frequency" knob to the "bypass" position. The WiiM Amp Pro will provide all the necessary filtering for the sub and for the main speakers (pretty much like AVRs do it).
