How to connect wiim ultra with KEF LSX ll speakers?
Fernandosan
How to connect wiim ultra with KEF LSX ll speakers? I have not been able to send sound to the speakers, I am using an optical cable and on the Ultra screen you can see that it receives the Spotify signal but the speakers do not sound
Obvious, I know, but have you checked that you've set the Ultra output to optical and the LSXs to optical input? I'm running an Ultra into a pair of original LSXs over TOSLink at 96/24 and have never had any problems.
Hello, I already did what you advised me and it already sounds but the sound is very, very low in volume. Do you know if I need to adjust something else?
I set my LSXs to about 50% volume and use the volume control on the Ultra. However, you could try setting the Ultra output to fixed at 100% and using the LSX volume to control the overall level. BTW, do you get low volume on all sources?
