How to control Lyrion Music Server on Wiim Pro Plus with Wiim Home
skooter
I am running Lyrion Music Server on a PC on the same local network as my Wiim Pro Plus. I followed the directions at https://faq.wiimhome.com/en/support...from-lms-to-your-wiim-device-with-squeezelite and am able to stream from LMS to the Wiim.
How do I control LMS with my phone? When I open Wiim Home, I can see the music server listed as a share but Wiim Home won't index the files and folders. I enabled Squeezelite on the device tab but don't see an option or way to access it through Wiim Home.
Am I missing something?
I
Install the Squeezer app on your phone.
Lyrion (LMS) doesn't expose the indexed tracks over DLNA (technically it can but it's very limited and no longer supported), so they're not accessible through the WHA.
When using Lyrion, the Pro Plus is just an endpoint (called SqueezeLite) controlled by the Lyrion web interface or a compatible app (see the section "Steps to Stream Music from LMS to Your WiiM device" in the link you posted).
Install Material plugin on Lyrion
iOS
Open http://lyrionipaddress:9000/material using Safari or Chrome on your phone
Do “Add to Home Screen”
Close the browser
There should now be a new Lyrion icon on your Home Screen
Use that
Android
Go to FDroid.com and find Material.apk
Download and install
Use that
The options are endless. :) I believe if he has an Android phone he would need to search for Lyrion to find the app on FDroid.
On android I simply enter http://lyrionipaddress:9000 and the material interface (enabled in lms) appears.
Then from the 3 bar menu in top right I simply choose 'Add page to' and choose 'Home screen' .
