So I understand I'm basically screwed because I act on impulse and never owned a Sub before, but here is the situation just to make sure.
I own a pair of Dali Rubicon 6C - active speakers with a "Connect hub" that manages the digital and analog inputs to the speakers wirelessly.
I also own and use the Wiim Ultra in which I use the DSP (EQ) to manage the horrendous room modes I have.
The "Wiim ultra" is connected to the "Connect hub" via SPDIF.
I only listen to streamed music via Qobuz and Tidal.
I just ordered a "SVS 1000 Pro" - subwoofer to more control of the bass by putting it somewhere in my room where it does not cause the same room modes and let it manage most of the bass instead of the front speakers.
And here of course I made a boo boo, since I need to use the DSP in Wiim to "cut" the bass frequencies from the front speakers, but I can not control the volume via Wiim since the speakers have their own digital amp and remote, and I would need use the "Wiims LFE out" which is analog and follows the volume set via Wiim.
I could connect the Sub to the "Connect hub" (it has a LFE connection) but it has no options for DSP or Crossover (expensive crap!) so it would still drive the main speakers at full range (confirmed by Dali tech), hence the sub would instead add to the bad bass.
Have I missed something or should I just sell it right away? (Along with these speakers that have only caused me issues!)
