Hi all,
I'm having an issue with Wiim amp audio out and ask if anyone else has experienced it.
My set up is very straightforward;
Passive speakers attached to the hard wire connections on the Wiim. No sub.
Connected via ethernet to listen to Spotify and internet services.
The only other input is optical from TV.
No HDMI, no line in and no Bluetooth in or out.
The problem is that I can be happily listening on ethernet and when I switch to optical, the speakers are switched off. Doesn't happen always which would probably help diagnose but does very often. The only way to get the speakers back on is to reboot.
Support are constantly associating with a Bluetooth issue as I cycle through the inputs using the remote from ethernet to optical but in my view, if one has chosen Audio Out to be speakers, no matter what the input is, they should not be affected. Do you agree?
Anyone else experienced this please?
All app and firmware up to date.
Thanks.
Thanks.
