Hi there,
I'm using the WIIM Amp since a few weeks, connected is a pair of Q Acoustics 3050i with 91 dB (6 Ohm) sensivity.
My expectation was that 60 watts into 8 ohms should be enough to drive the speakers at party level!
At 100% volume I measure at a distance of one meter just 88 dB at the peak with rock music.
Is that normal for the WIIM amp?
I´ve done already a reset to factory.
I can't complain about the sound, both CD via optical input and streams via Amazon sound really good....
Any ideas?
Thanks and best regards
Translated with www.DeepL.com/Translator (free version)
Any ideas?
