No Sound From Headphone Jack on Ultra
cottonchipper
To listen to headphones through the headphone jack on the front of the Ultra do I just plug into the jack? Are there any settings I need to change? I’m not getting any sound from the headphones (or even from earbuds plugged into the same socket). I do have a powered speaker connected to the Line Out, if that makes any difference.
I can't find a setting but wouldn't it be expected to automatically switch to the headphones out when connecting headphones? Should still be able to manually switch but having to do it every time is unnecessary.
Plus it would be convenient to turn off the trigger switch connected amp, if any, every time the output is not set to "line out" or any output that needs the amp for that matter.
You will always have to manually change to headphones. This will also allow you to turn down volume before connecting them.
