Normalize volume in wiim home app for Tidal
clive555
Perhaps I've missed this but is there a way to normalise the volume in the wiim app for Tidal?
No, but if you normalise it in the Tidal app and then use Tidal Connect, perhaps that will work?
No Tidal connect doesn't normalize anything and doesn't go to similar song at the end of of a Playlist or a single choosen song. When normal app is in use, exemple with headphones or android auto, it does both...
