What DAC? Capable of 192/24? DAC settings? Fixed resolution enabled or disabled?On Roon, it has stopped and just crackling thrrough DAC
Yes, does 32/386 as well but of course no useWhat DAC? Capable of 192/24? DAC settings? Fixed resolution enabled or disabled?
I try tomorrowWhat DAC? Capable of 192/24? DAC settings? Fixed resolution enabled or disabled?
Reboot yes but not factory reset. I'll try tomorrow. It was working and nothing has been changed - a Roon update perhaps.Have you tried a reboot or factory reset of your WiiM device, a different cable or connection to a different device to see if the problem persists?
Man, they've been in; out and shaken all aboutSilly question...
Is the cable in properly at both ends?
I had intermittent trouble with high sample rate files when my coax cable came out slightly.
Optical can only do 24/96, dohAnother coax cable? Optical one instead?
Then your dac is not so superb if it limits its toslink input.Optical can only do 24/96, doh
WiiM doesn’t limit optical nor coax resolution - I have a Mini happily delivering 24/192 over optical and a Pro delivering 24/192 over coax, both into my Linn MDSM/4. Neither are using expensive cables either. QEDIt's Wiim Pro that limits toslink. Have you read the spec?
No, it's not. I have plenty of WiiMs, all of them deliver 192/24 signal over toslink.It's Wiim Pro that limits toslink. Have you read the spec?
