I want to use my Wiim Pro to connect my PC to my Loxjie A30 integrated DAC. Basically I use the Wiim HTTP Api to switch between using the Wiim as a streamer and the PC Signal. Unfortunately, the streaming signal is incredibly loud in comparison to the "forwarded" PC digital signal. Is it possible to fix this volume issue without having to manually reducde/increase the volume on my dac for every input switch?
