JaywalkerHB
- Sep 6, 2025
Thank you for your answer, but unfortunately I can't seem to be able to find the menu that you screenshotted on my app.As far as I can remember, if you switch the WiiM’s input to anything other than Wi-Fi, the Bluetooth connection is lost. If the WiiM’s input remains set to Wi-Fi, the connection is keeped.
Please try switching to an input other than Wi-Fi using the “Standby source mode” feature added in the latest Amp pro firmware. I expect the firmware update to be available within a few days.
What I selected was: Devices, gear wheel icon on WIIM Amp Pro and then what? "Audio input"? There is no menu item called "Standby Mode Source". My app is set to German, but I think I should be able to tell if there is a similarly named menu.
