Brantome
- Oct 20, 2022
If you have the option toggled on in settings and aren’t using fixed volume output, you should see the volume slider set at the level you last used for each input. Just checked again on my Plus and it works fine@Brantome does the app fail to reflect the visually in real time? I tried hopping between sources in the app and expected to see the slider switch between the source levels, but it shows the same
