Pro Plus Owners: Has Any External DAC Transformed SQ For You?
Sketcher
Not finding much online regarding the Plus in conjunction with external DACs and was wondering if anyone is using such a combo and, if so, do you think it’s made a big, little, or no difference to overall sound quality. If it’s made a worthwhile difference to you, would love to hear about the rest of the system it’s making the difference in.
Thanks!
  • Like
Reactions: SWM
I think the Dac in the Pro Plus is amazing, I've had a few customers phone me to come listen, they have it in setups where you would expect to find the higher end steamers like Aurender and the likes.. and they can't stop singing it's praises.
I've have to agree that it's really really good, I hear a difference when I change over to my Theta Dac, it has more body and better Bass definition but I don't seem to miss it that much when listening to the Pro Plus internal Dac.
Noise and distortion of the WiiM’s internal DAC lays beyond non-audiophile hearing ability. Tho there are ppl out there who say they can actually hear difference between DACs, power supplies, cables, 16 and 24bits etc. I think the only way to know for sure is try an external DAC (better a few). If you think it sounds better - then yeah, it sounds better.
Not specifically the Pro Plus but I have the Pro connected to my Audio-GD R7 Mk2. It sounds amazing. I actually replaced a higher priced streamer for the Wiim when using Toslink.
I think you should experiment with different DACs yourself since people hear things differently. Also it depends on your setup. If you have some highly resolving headphones then you may well hear differences in DACs, amps, cables etc. If you are mainly listening through speakers in a normal room then the differences become much more difficult to detect.
It really is an experiment to see what sounds best in your system. I did a lot A/B testing to find the right combination for all my equipment. The more expensive option was not always the winner for me.
Don't forget about room treatment, speaker placement, and the EQ built into the Wiim. Those will probably do more for sound improvements than the DAC would and be cheaper. You can use REW with a calibrated mic to you 90% there then fine tune to taste. Do this last after you have the speakers and room treatment set.
Well said.
I have Wiim Pro Plus and I can tell you that the DAC section is amazing. I'm looking for an external DAC just because I want to start my CD Transport adventure. One and the only Digital In is taken by TV so... yeah. But other than that I am amazed how good it sounds and the funcionality! It was important for me that it switches input where the signal is and Pro Plus is working like a charm here! One more important thing. External linear power supply and power cables. I have pretty basic power supply with Furutech IEC socket (FI-03G) and Furutech Alpha 3 (28/38G) connected to it. BIG difference!
