Questions about WiiM Pro/Ultra
Macintosh
I wanted to ask some questions before my purchase of either WiiM Ultra or Pro, I want to use them as a DAC with Room Correction for my monitors. So my questions are
- Do they have an soft-start so it avoids making a "pop" sound when they are turned on or off ?
- Can I control the volume using my Samsung TV remote or my Chromecast one? Do I need to use HDMI ARC for it?
- How well does the Room Correction, how does it compares to something like MiniDSP and can it helps when an speaker is further away than the other ( stereo imbalance ) ?
- How well does the phono works and how does it compares to like a small phono box?
- Is the screen always on or only when you use the remote ?
Thank you in advance for your answer
