Replacing a Wiim Pro with Wiim Pro Plus
xgrep5
I just bought a Wiim Pro Plus to replace my Wiim Pro. What's a good way to do this without having to write down and re-enter all of the settings from the old device, which I plan to reset to factory defaults so that I can gift it or sell it? Is there a way to export/save settings somewhere and then re-import them to the new device? One thing that may simplify the task is that my connection is Ethernet.
Also, the new device will probably need a firmware update. Should I do that before or after completing full setup?
Thanks in advance for your thoughts.
Unfortunately there’s no way to copy settings between devices.
Doesn’t really matter when you’d do the firmware update.
Thank you, I thought that might be the case. Oh well, I'll only have to do it once (but the Alexa and Apple Home stuff sometimes take a bit of work).
Strangely, when I searched for this, I didn't see the other thread that's essentially identical that you replied to. Well, now there are two (maybe soon three ...).
Thank you. I'm hoping to! Will allow me to eliminate the DAC that I currently feed from the Wiim Pro (an excellent little Topping that uses the same DAC chip as the Plus). Even better, the ADC on the line input side is a better chip than on the Pro, so it will be interesting to see if there's an audible difference (but very hard to test if I don't have both Wiim Pros running!). But these things are subtle and depend on many things, including room acoustics, amps, speakers, etc., so whatever I find is only marginally useful to anyone else. I'll just have to settle for the satisfaction of knowing (which is half of audiophilia, isn't it?).
I have a much more expensive DAC at home (Metrum NOS DAC), which I found, (it also got excellent praise), and still find excellent! However, the DAC in the Pro+ is really very fine as well! In fact, I don’t use the Metrum DAC anymore! Too small are the perceived differences… if there are any…
I had heard of Metrum ... way out of my price range. I was under the impression that it was a discreet design or a proprietary chip, but I could be wrong about that. That said, DAC performance depends on more than just the chip chosen. Power supply, clock, etc. Some things are easy to hear, others not so much. I was never able to hear the effect of green magic marker around the edge of a CD in double-blind tests (for folks who were around when that was an audiophile thing).
Anyway, I'm glad to hear that you're pleased with the Pro+. I haven't had a chance to set it up, yet (it will take around an hour, I figure).
I set it up today it's interesting that the analog out from the Topping outboard DAC sounds different than directly from the Pro+ even though they have the same DAC chip. I tried adjusting for possible difference in volume, but don't have my distortion and frequency response equipment to see if there are any differences there. In any case, the line out of the Pro+ sounds "better" than with the Topping DAC, having more "presence". I'm certainly not disappointed, and will keep experimenting ...
