I'd like a way to assign different RoomFit profiles to preset buttons on the remote control. My previous room correction settings were moved to RoomFit with the latest update, so I'm no longer able to choose them with smart presets or from the "Now Playing" screen.
I use two different RoomFit profiles, one for sitting in the sweet spot and one for reclining on my daybed, which is against the wall with "boomier" low frequencies and different distances to stereo speakers.
Maybe an additional option for this can be added to Smart Presets similar to the pull-down choices for other settings:
"Follow Current RoomFit", "RoomFit Off" or selecting a saved RoomFit profile.
Another way to handle this would an option to send RoomFit settings to PEQ ("Export to PEQ" or "Save to PEQ"), which could then be configured as a Smart Preset. Entering by hand 20 settings with four parameters into PEQ is way too kludgy and subject to error. This would also make exported RoomFit settings directly selectable from the "Now Playing" screen.
Or ideally both methods would be available. ;-)
Upvote
11
