Wiim User #6832
- Feb 12, 2023
I have my Mini connected via SPDIF optical directly to my Edifier R1280DB powered speakers. The highest output resolution setting I can select in the WiiM app and hear the test tune is 24 bits/48 kHz.
1. I assume this limitation is due to a limitation of the speakers I'm using. Is this correct?
2. My streaming service is Spotify Premium. If Spotify ever comes out with a HiFi level I assume I will need to upgrade my speakers if I want to take full advantage of Spotify's new hi-res level. Is this correct?
3. When shopping for upgraded speakers, what specs do I look for to be sure they will support hi-res streaming up to 24 bits/192 kHz?
Thanks.
Thanks.
