Stacking Pro/Pro Plus
PhxComm
When using these in a rack, can you stack the Pro and/or Plus Plus (and Ultra I suppose I should ask about too) on top of each other? How many? Otherwise, they'd have to go on shelves. How many on a shelf if ok? 2 will fit, not sure about 3, is that ok? When two/three are on their own shelf side-by-side, is just the 1U enough space? Nothing indicates where and how these are cooled.
Same questions for Amp, posted in Amp section.
Did you figure this out? I also plan to have two WiiMs in a rack but it looks like there is no 1st party rack mount solution
Anyone with rack can please share your experience?
My pros and ultra hardly get warm after significant use, I can't imagine heat issues stacking them.
The amp is a different matter, obviously.
Hi, no, I have no new information other than the last post. I've stacked Sonos Ports and pretty sure that's ok, so I'm thinking these will be just fine too. The amps are a different challenge.
