wiimhome.mlqzv
- Jun 4, 2024
I'm a relatively new WiiM'er having moved over from Sonos. I'm very happy with WiiM, but there's one aspect to how WiiM is implemented that is driving me crazy. It's not exactly WiiM's "fault" or error, but it is a byproduct of how WiiM has decided to leverage Spotify as a service. I don't think there's any solution here - I think it's just an annoying limitation of the Bluetooth spec - but I'm curious if maybe someone out there knows something I don't?
The quick summary: While Sonos connects directly to Spotify and essentially IS the streaming device, WiiM really just pushes you over to your phone's app and your phone is the streaming device. But this really "locks" in your phone to WiiM and so many other phone actions can then very easily disrupt the stream.
The biggest problem I keep having is that if I just turn ON another Bluetooth device (say, a pair of headphones), my phone will immediately connect to it, and suddenly the stream from the Spotify app that had been playing through WiiM is now playing through the pair of headphones. The entirely house is disrupted and I have to manually re-direct streams. Every time I have a stream playing through the house and I decide to listen to a podcast on my phone... I have to go through this dance. I've even had to completely "forget" some always on Bluetooth devices because it just caused too many problems.
Does anyone know a workround for this? Is WiiM perhaps going to more tightly integrate Spotify so that it eliminates this device-reliance problem?
Thanks!
Thanks!
