(I've started talking to Wiim's support staff on this question, but thought I'd throw it out here too.)
So I have an old turntable (Stanton STR8-50) that I want to be able to play though a set of Apple Homepods. I bought a Wiim Pro, plugged it in and connected it up but there's an issue. The volume coming out of the homepods is really low.
There are no volume controls on the turntable – it's a solid piece of kit but was originally purchased to be connected to a separate amplifier and speakers and doesn't have a pre-amp in it.
Everywhere in the chain I can find a volume control, I have it turned up. The Homepods work fine - they're super loud - so is there some way to tell the Wiim Pro to boost the signal that I'm missing? The turntable is plugged directly into the back of the Wiim Pro’s red and white RCA ports, and it's set up as an Airplay 2 device in the Home app on my phone. The systems is working, because there IS audio coming out of the homepods - it's just super quiet.
Before I purchased the Wiim Pro I searched online to see if it could function as a pre-amp and the responses from reddit etc seemed to imply that it could but I'm now thinking maybe the signal from the turntable needs to be boosted before it connects to the Wiim Pro? I’ve ordered a 25 euro phono-preamp from Amazon to be delivered tomorrow. It should hopefully boost the audio coming out of the turntable before it gets to the Wiim Pro.
So is this as simple as you have to have a pre-amp to boost the signal of a turntable to make it loud enough to listen to, or is there a software setting I'm missing that would make the Wiim Pro act as a pre-amp and boost the signal?
Thanks all!
Thanks all!
