Kblade97
Valued Contributor
- Dec 14, 2023
And I don’t have that problem whatsoever. The sub out on the NAD is going to be have higher quality signal than the ultra all in one box doing many things. Also, I believe you’re making it more difficult for set up because you’re trying to get the sub to go up to where you cut off the frequency response of your mains. Makes for a way more difficult set up in my opinion. now, if we’re talking about home theater, it could be different. For example, below I cross over my Revel F208 at 60 Hz and then tuck the sub underneath them, but that’s for home theater. And I’m talking about Dirac doing that I’m not. It’s the software doing it for home theaterAn opinion based on the difficulty in matching the speaker natural roll off to the sub low pass filter. I could never get mine sounding right before I got the WiiM Amp.
