Suggestion for easier screen navigation & fixed volume confirmation
Fralle
Valued Contributor
I find the "Are you sure you want to switch to Phono?" message quite irritating. It unnecessarily complicates navigation in the touchscreen settings and doesn't seem to serve a meaningful purpose. I believe it should be removed to improve usability.
Instead, a confirmation message should be added when enabling the fixed volume setting. Since this option is prominently displayed on the screen, it's far too easy to activate it accidentally—potentially damaging speakers and harming hearing.
So, here are two suggestions for a future update:
  1. Remove the confirmation prompt for switching inputs.
  2. Add a confirmation prompt when enabling fixed volume.
Actually I think the fixed volume is so dangerous it should maybe even be two confirmations if possible. This is a set and forget setting for most people, but extremely dangerous for all of us using it as a preamp connected directly to a power amp.
Would love to hear what others think!
Upvote 5
