Welcome to Tech Tuesday! This week, we’re unpacking one of the most misunderstood parts of the audio world: codecs. If you’ve ever wondered why some songs sound amazing and others… not so much, or why your FLAC files won’t play over Bluetooth, this one’s for you.
Whether you’re streaming from your phone, plugging in a USB drive, or building out a home theater with your WiiM setup, understanding codecs helps you get the best sound possible and make the right decisions for your audio.
Let’s keep it simple: a codec is a way of compressing and decompressing audio. Audio codecs are essentially the "languages" that digital audio files speak. A codec is a combination of the words coder/decoder. It is a device or computer program which encodes or decodes a data stream or signal. In the case of audio, it compresses the file for transmission and decompresses the received files upon playback.
Think of it as a sophisticated filing system that determines how your music is stored, how much space it takes up, and what quality you can expect when you play it back. Some codecs prioritize quality. Others prioritize speed or file size. And some try to balance all three.
Codecs play a huge role in audio since they affect your listening experience. You could be using a very high-end device for streaming music, but ultimately, your experience will depend on several factors, a big one being the codec that has been chosen to process the audio file you're listening to.
Sample Rate: Simply put, this is how many times per second the audio is sampled. More samples allow for accurate reproduction of higher frequencies within the audible and inaudible ranges and help prevent aliasing distortion. 44.1kHz is standard for CDs, while 48kHz is common in movies and video. It is measured in samples per second or Hertz (Hz/kHz). The sample rate determines the maximum frequency that can be accurately captured. Higher sample rates can help with technical aspects like filter design and processing headroom, but for most listening situations, standard rates capture all audible frequencies perfectly and modern ADCs and DACs like we use in WiiM devices implement almost perfect filters and vanishingly low noise even at 44.1kHz sample rate.
Sample Depth: Also known as bit depth, sample size, or sample precision, it refers to how precisely each audio sample's amplitude is measured. This determines the dynamic range of the recording which is essentially how quiet a sound can be before it gets lost in the noise floor. 16-bit audio offers about ~96dB of dynamic range, which covers the full range from the quietest sounds humans can hear up to to uncomfortably loud levels. 24-bit audio provides a theoretical ~144dB of dynamic range, offering much more headroom for recording and mixing, though the difference is rarely, if ever, audible in final playback in the home. Higher bit depths are primarily beneficial during recording and production stages.
Bit Rate: This is how much data is processed every second, measured in bits per second (bps or kbps). For uncompressed audio, bit rate is calculated by multiplying sample rate, bit depth, and number of channels. However, for compressed audio formats (like MP3, AAC, or Ogg), bit rate is determined by the compression algorithm and quality settings, independent of the original sample rate and bit depth. Higher bit rates in compressed formats generally mean better sound quality and larger file sizes, while lower bit rates result in smaller files but potential quality loss due to compression artifacts.
Lossy: These formats shrink the file by cutting out audio data. MP3 and AAC are common here. They save space but lose some sound quality, especially at lower bitrates. Lossy audio involves a high degree of compression but doesn't decompress files back to their original data amount.
Lossless: These compress the file without losing any audio data. FLAC and ALAC are good examples. You get CD-quality sound in a smaller file.
Uncompressed: As in… not compressed, and you guessed it, it doesn’t have any compression at all. WAV and AIFF fall into this group. They sound great, with the same audio as Lossless, but take up a lot more space… about 10MB per minute of audio.
You could have top-tier speakers, but if your audio file is heavily compressed, you’re not hearing everything. On the flip side, trying to stream a massive WAV file over Bluetooth might cause lag or dropouts.
Knowing your codecs helps you:
Next up, we’ll break down which formats WiiM devices actually support and how to choose the best one for your setup.
Here’s a breakdown of what’s supported and when to use each format.
AIFF (Audio Interchange File Format) AIFF is Apple’s version of uncompressed audio. It’s big, clean, and sounds great. It also supports rich metadata, so you can include album art, song titles, and more. All WiiM devices support AIFF and its compressed variant (.aifc). You can stream these through the WiiM Home app or DLNA.
WAV (Waveform Audio File Format) WAV files are uncompressed and sound exactly like the original recording. They’re large, so not ideal for streaming over weak connections, but perfect for short clips or high-quality playback. Supported across all WiiM devices.
ALAC (Apple Lossless Audio Codec) ALAC is Apple’s version of FLAC. It compresses audio without losing quality and works well in Apple’s ecosystem. WiiM devices support ALAC, so if your library is built in iTunes or Apple Music, you’re good to go.
DSD (Direct Stream Digital)
MP3 (Moving Picture Experts Group Layer-3 Audio) Still the most common format around. MP3 files are small and compatible with just about everything. WiiM devices support sampling rates from 8kHz to 48kHz and bitrates from 8kbps to 320kbps, including variable bit rate (VBR). At higher bitrates, MP3 sounds pretty good. At lower ones, you’ll notice the drop in quality.
AAC (Advanced Audio Coding) AAC is Apple’s preferred format and is used by Apple Music and YouTube. It’s more efficient than MP3, so you get better sound at the same file size. WiiM devices support AAC across the board.
WMA (Windows Media Audio) WMA is Microsoft’s lossy format. It’s compact and sounds decent, especially over Bluetooth. Not widely supported by streaming services, and not necessarily compatible with Apple devices, but WiiM supports it at 44.1kHz and 48kHz.
The beauty of WiiM devices lies in their flexibility and customization. They can handle almost any audio format you throw at them while maintaining excellent sound quality. Whether you're a casual listener who wants convenience or an audiophile seeking maximum fidelity, understanding these codec basics will help you get the most from your WiiM ecosystem.
At the end of the day, it is a trade-off you're going to have to make. You have to decide what you value more and in what order:
Wi-Fi matters more than you think. Even if your files are high quality, a weak or unstable connection can cause:
Tip: Use 5 or 6GHz Wi-Fi if possible. It’s faster and less crowded than 2.4GHz, especially in apartments or dense neighborhoods.
How you connect your WiiM device to your speakers or amp affects sound quality.
Tip: If you’re using analog output, check your device’s DAC specs. WiiM Ultra uses the ESS Sabre DAC, which sounds noticeably cleaner than the Mini or Pro.
Have questions about specific audio formats or need help optimizing your setup? Join the discussion, fellow users and WiiM team members are always happy to help! Anything missing from this doc, or think it needs clarifications or changes, speak up too!
What Are Audio Codecs?
The Foundation: Sample Rate, Sample Depth, and Bit Rate
The quality of an audio file is dependent primarily on three variables: sample rate, sample depth and bit rate. These variables are used when analog audio is converted into digital audio, and affect the overall audio quality. The higher each of these three variables are, the better your audio is going to sound. This also means the data transfer is larger, and so the connection to the source needs to be faster and more reliable.Sample Rate: Simply put, this is how many times per second the audio is sampled. More samples allow for accurate reproduction of higher frequencies within the audible and inaudible ranges and help prevent aliasing distortion. 44.1kHz is standard for CDs, while 48kHz is common in movies and video. It is measured in samples per second or Hertz (Hz/kHz). The sample rate determines the maximum frequency that can be accurately captured. Higher sample rates can help with technical aspects like filter design and processing headroom, but for most listening situations, standard rates capture all audible frequencies perfectly and modern ADCs and DACs like we use in WiiM devices implement almost perfect filters and vanishingly low noise even at 44.1kHz sample rate.
The Bit Rate, Sample Depth, and Sample Rate all show on a WiiM Ultra or Amp Ultra screen right at the bottom.
Compression Types: The Trade-offs
There are essentially three kinds of audio compression techniques.Lossy: These formats shrink the file by cutting out audio data. MP3 and AAC are common here. They save space but lose some sound quality, especially at lower bitrates. Lossy audio involves a high degree of compression but doesn't decompress files back to their original data amount.
Why It Matters for WiiM Users
You could have top-tier speakers, but if your audio file is heavily compressed, you’re not hearing everything. On the flip side, trying to stream a massive WAV file over Bluetooth might cause lag or dropouts.Knowing your codecs helps you:
- Pick the right format for your setup
- Avoid compatibility issues
- Maximize sound quality without wasting space
Audio Formats Supported by WiiM Devices
Your WiiM devices are incredibly versatile when it comes to audio format support. Whether you're streaming from a service, playing files off a USB drive, or setting up a multi-room system, knowing what formats work best can save you time and help you get better sound.Here’s a breakdown of what’s supported and when to use each format.
Lossless Formats
FLAC (Free Lossless Audio Codec) FLAC compresses audio without sacrificing quality. You get uncompressed audio in a smaller file which works out to be usually about half the size of the same content in WAV format, with 16-bit, 44.1 kHz FLAC files you'll get CD-quality audio. It’s open-source, widely supported, and works across all WiiM devices. FLAC can go up to 32-bit, 96kHz, which is better than CD quality. Perfect for building a high-res library without eating up all your storage.AIFF (Audio Interchange File Format) AIFF is Apple’s version of uncompressed audio. It’s big, clean, and sounds great. It also supports rich metadata, so you can include album art, song titles, and more. All WiiM devices support AIFF and its compressed variant (.aifc). You can stream these through the WiiM Home app or DLNA.
High-Resolution Audio
- Ultra-high-resolution format originally used for SACDs
- Supported on all WiiM devices except the WiiM Mini
- WiiM devices convert DSD to PCM (up to 192kHz) for playback
- Supports both .dsf and .dsd file extensions
- Note: DSD files are converted to PCM format rather than played natively
Lossy Formats
Surround Sound and Multi-Channel Audio
Dolby Digital 5.1
WiiM Ultra, WiiM Amp Ultra, and WiiM Amp Pro support Dolby Digital 5.1 surround sound, opening up exciting possibilities for home theater setups:- Input: Via HDMI ARC and Optical connections
- Channel support: 5.1 channels (Front Left/Right, Center, Surround Left/Right, plus Subwoofer)
- Setup: Uses multiple WiiM devices in a multi-room configuration
- Current limitation: Dolby Digital 5.1 is the only surround format supported (no Dolby Atmos or DTS)
Bluetooth Audio Codecs
WiiM devices support several Bluetooth audio codecs for wireless streaming:Currently Supported
- SBC (Sub-Band Coding): Universal Bluetooth codec, basic quality
- AAC (Advanced Audio Coding): Better quality, especially with Apple devices
- LC3 (Low Complexity Communications Codec): Available on WiiM Ultra as part of Bluetooth LE Audio
Playlist Formats
M3U Playlists
If you’re using a USB drive, WiiM devices with USB ports (Amp, Amp Pro, Amp Ultra, Ultra) support M3U playlists. Just make sure:- The playlist is encoded in UTF-8
- You use relative file paths, not absolute ones
- You store the playlist anywhere on the USB drive
- You include track duration and metadata if you want it to show up
Code:
#EXTM3U
#EXTINF:123,Artist 1 - Song 1
song1.mp3
#EXTINF:145,Artist 2 - Song 2
Album1/song2.mp3
Getting the Best Results
Understanding audio codecs helps you make informed decisions about your music collection and streaming setup. Here are key takeaways:- For archiving CDs: Use FLAC for the perfect balance of quality and file size
- For portable devices: MP3 320kbps or AAC 256kbps work well if you’re not as worried about the quality.
- For critical listening: Stick to lossless formats and wired connections
- For home theater: WiiM Ultra or WiiM Amp Ultra with Dolby Digital 5.1 setups
- For streaming: Choose services that match your quality preferences, libraries, and features.
Which Audio Format Is Best For You?
It has to be said that there is conflicting online information on this topic. And that is probably because there is no right answer to this question. It depends on what you prioritize more. A lossless or uncompressed audio file format is the best format for sound quality. These include FLAC, WAV or AIFF. These types of files are considered "hi-res" because they are equal to or better than CD-quality. The tradeoff is that these files will be very large.At the end of the day, it is a trade-off you're going to have to make. You have to decide what you value more and in what order:
- Sound quality: Choose lossless (FLAC, AIFF, WAV) or high-bitrate lossy formats
- Storage space: Lossy formats like MP3 320kbps or AAC 256kbps offer good quality with reasonable file sizes
- Download time/Streaming: Lower bitrate files stream faster but with reduced quality
For Bit-Perfect Audio Playback
- Use lossless formats (FLAC, AIFF, WAV) for your music library
- Connect via wired connections (HDMI ARC, Optical, Coaxial) when possible
- Set fixed volume at 100% and disable EQ when using external DACs
- Use USB drives formatted correctly with UTF-8 encoding for playlists
For Convenience vs. Quality Balance
- MP3 320kbps or AAC 256kbps offer excellent quality with reasonable file sizes
- FLAC files provide perfect quality with good compression
- Streaming services like Qobuz, Amazon Music, and Tidal offer high-quality options
For Surround Sound
- Ensure TV outputs Dolby Digital 5.1 in audio settings
- Use HDMI ARC or Optical connections to WiiM Ultra, WiiM Amp Ultra, or Amp Pro
- Set up additional WiiM devices for surround channels
- Configure through WiiM Home app for proper speaker placement
Streaming Service Compatibility
Your WiiM devices work with numerous streaming services:- Spotify, Apple Music (via Bluetooth/Casting)
- Amazon Music, Qobuz, Tidal, YouTube Music (native integration)
- Internet Radio (including custom URL storage)
- Home Music Share (DLNA from local servers)
Technical Limitations to Know
Network Stability
Wi-Fi matters more than you think. Even if your files are high quality, a weak or unstable connection can cause:- Dropouts or buffering
- Lower resolution playback (some services auto-adjust)
- Sync issues in multi-room setups
Connection Type
How you connect your WiiM device to your speakers or amp affects sound quality.Connection Type | Quality Impact | Notes |
| Optical (TOSLINK) | Excellent | Supports up to 24-bit/192kHz PCM. Clean and reliable. |
| Coaxial | Excellent | Similar to optical, but uses electrical signals. |
| USB DAC | Best | WiiM Ultra supports USB audio out. Great for high-end DACs. |
| RCA Analog | Good | Depends on the DAC inside your WiiM device. Pro Plus and Ultra have upgraded DACs. |
| Bluetooth | Variable | Depends on codec (AAC, SBC, LC3). Convenient, but not ideal for critical listening. |
| HDMI ARC | Excellent | WiiM Ultra and Amp Ultra support HDMI ARC with Dolby Digital. Great for TV setups. |
What's Next?
Audio codec support continues to evolve with firmware update. Keep an eye on firmware updates and community discussions for the latest developments!Have questions about specific audio formats or need help optimizing your setup? Join the discussion, fellow users and WiiM team members are always happy to help! Anything missing from this doc, or think it needs clarifications or changes, speak up too!
