Pragmatist
- Mar 30, 2025
It is not necessarily a DAC issue. It can be caused by any of the electronics or by the speakers. The amp or speakers are the mostly likely cause.I’m quite surprised about the ‘headache’ phenomena.
For starters, it’s not a hi-fi problem, it’s a medical problem induced by hi-fi.
Very easy to figure out if a different DAC is causing it. Get your little helper to choose the DAC for the night, unsighted by you. Have an evening’s listening. Ask your helper to randomly choose a DAC for the next night. Could be the same DAC, could be the second DAC.
Get them to keep a diary of which DAC it was on which night, and you keep a diary of when you get a headache.
I am pretty sure if I played a treble leaning system at high volume I would get a headacheHeadache inducing speakers are the most easily sold. They sound engaging in the shop and when you come back home where the floor isn't carpet tiles and the ceiling not sound absorbers and you tend to listen for an extended period of time it's different.
My ears are older than me. Funnily enough my rather good Phonaks were set up with measurements and some twenty minutes of A/B testing. There's less to our hearing tham most audiophiles think. There's also more to how we feel a day or a moment than there is to our equipment.
This video discusses why out hearing/perception is, in fact, very sensitive and not entirely understood.There's less to our hearing tham most audiophiles think.
Yeah. But he has used the term "infinitely sensitive" one too many times for anyone to take him seriously.This video discusses why out hearing/perception is, in fact, very sensitive and not entirely understood.
Wouldn’t cut it for you……or your significant other?I'd add location to that excellent list - while some might be happy with a non-descript plastic box, a bulky external power supply and a mass of cables in their "man-cave", that just wouldn't cut it for me in my living room
The discussion in this video is based on a per reviewed paper published in the scientific publication Applied Acoustics. The author is a professor in the department of Physics and Astrophysics at the University of South Carolina. He specializes in the fields of audio and acoustics and in quantum phenomena at low temperatures. I would not dismiss his work so lightly.Yeah. But he has used the term "infinitely sensitive" one too many times for anyone to take him seriously.
I don’t see the pertinence of that questionWouldn’t cut it for you……or your significant other?![]()
Correct. What the guy on the video is discussing is the contents of Kunchur's paper. The content he presented is published research from an expert in the field. That content should be taken seriously. The "for anyone to take him seriously" comment seemed to imply that the whole content of the video should not be taken seriously. Hence my comment.^It’s not Kunchur in the video, right?
With electronics it can be valid with A/B if you can be sure you listen to exact the same volume. For stereo speakers its impossible because they only sound great when properly installed +- 5 cm with the correct distance between them, distance to frontwall , opening angle and so on. A good constructor of loudspeakers in a stereosetup mention this in the setup manual. And yes - different speakers need very different installation positions in a listening room, so one cant just place them at the same spot when doing A/B listening.A late friend of mine and I both had the Slimdevices Transporter back in the day. It was a nonplusultra streamer for local files, managed by Slimserver (now Lyrion Music Server) in 2007. Here are the Stereophile measurements:
My friend found that the Transorter was AC-coupled and that it had non-audiophile electrolytic capacitors in series with it's outputs. He changed them for somethinng expensive from Mundorf (I think it was Mundord) and heard all the difference in the world. Very pleased he was.![]()
Slim Devices Transporter network music player Measurements
Sidebar 3: Measurementswww.stereophile.com
He asked to borrow my unmodoified one to do the changes to mine too. But he did an A/B comparison first.
No difference. Absolutely none.
Then he found that the outputs were at +5V, so the serial capacitors input voltage would never cross 0 V. Suddenly no difference made sense.
My take:A/B testing works. It zeroes euphoria and lets your ears find audible differences. If your hearing's up to snuff. Mine was back then. Good times. Damn fine looking box, the Transporter. Lovely VU meters too.
I absolutely didn't not want to imply that.Correct. What the guy on the video is discussing is the contents of Kunchur's paper. The content he presented is published research from an expert in the field. That content should be taken seriously. The "for anyone to take him seriously" comment seemed to imply that the whole content of the video should not be taken seriously. Hence my comment.
My point was that
"That effect indicates that there is more to our hearing that can be determined in a few minutes of A/B testing."
One complicated but more valid way to compare 2 pair of loudspeakers is to optimise the setup of one pair at a time in the room , putting tape on the exact spot on the floor, and then carry out the speakers from the room when comparing to another pair of speakers ( also optimised with tape on the floor to find the best sounding spot ).
It will take some time to do comparisons this way, but the result will be more valid.
Peer reviewed papers are only as good as the peers who review them. I have first hand knowledge of a PhD student who wrote a thesis full of inaccuracies about work done for a company I worked for. His supervisor who I assume reviewed it seemed to have no issue with it. One of his main conclusions was that the toroidal core of one of our variable transformers could be optimised by reducing the cross sectional area to half the current size which was clearly BS but his supervisor clearly believed itCorrect. What the guy on the video is discussing is the contents of Kunchur's paper. The content he presented is published research from an expert in the field. That content should be taken seriously. The "for anyone to take him seriously" comment seemed to imply that the whole content of the video should not be taken seriously. Hence my comment.
