Rob Zmusic
- May 5, 2024
I'm having an app connection issue and could use some help. I have 2 systems set up. One with a Wiim Amp, and one with a Wiim Pro Plus. Up until about a week ago, both systems performed completely as advertised.
Then, all of a sudden, the Spotify Connect and Tidal Connect will no longer connect to either of the Wiims through their respective apps. When you select the Wiim you want from the Connect list, it just says "searching" and never finds it. Apple Airplay still works fine on both, and connecting direct with my laptop still works perfectly. These apps just wont connect to the Wiims directly.
So far, the steps I have taken to correct this are:
- Have restarted the apps.
- Have deleted and reinstalled all of the apps (Spotify, Tidal and Wiim)
- Have rebooted both Wiims
- Have rebooted wifi router
- Have disabled IPv6 in both Wiim's network settings
- Have tried enabling "preferred DNS server" of 8.8.8.8 on the Wiims
After all of that, I have no change to the problem. I feel like I must be missing something somewhere. I doubt there is something wrong with them since its the same from both units that started at the same time. Seems like its somehow a problem with my network, but I dont know what or how to fix it. Any ideas?
