Dennis from Venice
Active Member
- Jul 18, 2024
I have a Mac Mini with the latest OS and a WiiM Ultra with USB out to a DAC. The Tidal connect works fine initially and when I start Tidal on the Mac, the WiiM Ultra appears in the options for audio out. When I play Music on Tidal, it correctly plays on the WiiM. Then after about 5 minutes or so, the audio option in the Tidal APP switches from the WiiM to "Default" -- the Mac speakers.
I have been using the Tidal playlists of classical music. Some music seems to play correctly for longer than 5 minutes but I haven't found a solution as eventually, it resorts to Default.
I then tried playing the same music from the WiiM Tidal option. And after about 20 minutes, the music stopped and after I hit the play button, it resumed.
I just rebooted the WiiM, the Mac, and the Router. Now when I choose the WiiM in the Mac APP it immediately goes to the Mac speakers (default)
I also have JRiver with DLNA to the Wiim, which works fine....just the Tidal is having issues.
