Tidal resolution issue on WHA via WiFi?
poldark
Not sure is there's a set up issue here or not.
Playing Tidal via WHA out to SU1 on Coax and playback is reported at 16/44.1 but should be 24/192?
I have max resolution set for Opt & Coax inputs, but this is via WiFi, so is there a resolution cap here?
Thanks
Tried all the options and only get full 24/192 if I playback via Tidal Connect through it's own App, lower resolution through WHA or LMS
Ah, interesting, now back in WHA I get the proper higher resolution with a Tidal Connect symbol I've never seen before!
So does this mean I need(ed) to instigate a Tidal Connect playback through Tidal App, as I was accessing Tidal directly from WHA before and didn't get 24/192 - confused (easily done!)
