trickydicky1321
- Mar 13, 2023
Move theWould be possible to look into a fix for this.
If I want to play a track from the beginning, it skips back to the track before.
In case of not being able to explain myself properly, attached a screenshot.
TIA
Move the volume slider with your finger to play from the beginning of the track.
Hadn’t even spotted that!I made a writing error and have corrected it.
volumeslider
Hi Trickydicky1321,Would be possible to look into a fix for this.
TIA
If so, will it be inpossible to skip to the previous track? Perhaps need to be able to do both.Hi Trickydicky1321,
hank you for your feedback! I’ve shared your feature request with our team, and we’re working on a plan to implement it. Stay tuned for updates!
Why should it change? It works nicely as it is now.It's funny how wiim's reply implies this has never been mentioned before
Regardless, I hope this gets implemented intelligently, as discussed before!
Or just as it is now. Press Back and then Forward. That is more logical.Can this not be done like it is done in the Apple Music app?
Pressing skip back takes you back to the start of the current track, but if pressed twice in quick succession it takes you to the previous track.
Yes, I agree.I actually like it the way it is.
Prev - Go to previous track
Forw - Go to next track
Slider - Adjust position, including start of track.
If you use the remote there is of course no slider, so press Rew, then Forward.
It works fine as it is now!Yes, I agree.
It would be sad if this update would not allow skipping to the previous track.
I think it needs to be at least like this way.
Tap to skip
Long press to move the slide bar
Of course it is, but the team says they will update it. So I Suggested with a compromise!It works fine as it is now!
I don't think @WiiM Team understood the requirement compared to what is already working. They are just nice and respondOf course it is, but the team says they will update it. So I Suggested with a compromise!
LMS has the same behaviour.Can this not be done like it is done in the Apple Music app?
Well, maybe...I don't think @WiiM Team understood the requirement compared to what is already working. They are just nice and respond
I have never used apple music so I would like to ask, if you press the skip back button once within 3 seconds of a track starting to play, does it go back to the previous track?Can this not be done like it is done in the Apple Music app?
Hi Wiimer,I have never used apple music so I would like to ask, if you press the skip back button once within 3 seconds of a track starting to play, does it go back to the previous track?
(If 3 seconds have elapsed since the start of playback, it will return to the beginning of the track.)
As far as I know Spotify, AMU, Qobuz apps all work the same way.
Thank you.
