Use as Audio Device over LAN? Cant find Wiim Pro as option.
dweeeeb2
Hi, I'm trying to use an EQ on my laptop but i can't add the wiimPro as an audio output device over LAN. I can chromecast to it but then my EQ doesn't work. Please tell me I'm doing something wrong!
Depends on how do you apply the EQ. If it's applied to the source stream then published and casted over chromecast, it will work. Otherwise you can use WiiM home app to apply EQ settings.
