I will shortly be adding a Wiim Pro to my main system which means I can move my Wiim Mini to feed a Bluetooth speaker in another room. My question is if I want nicely synced audio across the two rooms will it be OK to use Bluetooth or should I wire the Mini to the speaker? Ideally I would like to hide the Mini on the other side of the room to where the speaker is so Bluetooth would be preferable.
