dimangiful
- Jan 16, 2024
Setting the volume limit doesn’t just limit the max output. It also changes the entire volume range. Without the limit i normally listen at around 30% from the volume slider. Setting the limit at 80%, i need to move the volume slider to 50% for the same result. Also, the max volume is subjectively nowhere near 80%, more like 50.
Others have the same experince?
