I am using the WiiM Pro Plus for music services (currently mostly Spotify), for analog and digital sources (mainly Vinyl and CD) via line in, and as a DAC - the Plus is connected via LR/RCA line out to a vintage receiver which then feeds wired speakers (and a sub). So the receiver serves basically as an amp.
I mostly listen at lower volumes and only occasionally crank it up.
I like crisp clear sound in all frequencies and would like to hear details at all volume levels.
If relevant, I have 3 sets of speakers (currently wired) in a large, open space. Some will be replaced with wireless speakers soon.
What is the best setting on the Pro Plus for me to get max sound quality in this setup, at any volume?
Do I get better sound when I control the volume in the WiiM resp. music service apps (which is convenient) or should I keep the WiiM at max volume and control the volume on the receiver only?
Volume of the Pro all the way up? Fixed volume? EQ? What is pEQ? Room correction?
How does this all work together and what is the optimal solution for best souls at all volume levels?
Thank you!
Thank you!
