jamiington2004
- May 16, 2023
Anyone else find the volume will only jump 2 or 3 steps at a time especially at low volumes?
Even using the iPhone control panel volume slider - it just visibly drops back down to previous level and volume doesn’t change, if I try and fine tune the volume by 1 or 2 steps
And same with remote although doesn’t seem as bad - I click once and sometimes it jumps several steps in volume
Spotify connect > Wiim Pro > digital coax out to speakers
Latest software
Thanks for any advice on how to fix this
Latest software
