Volume
mrroyal88
Hello
I love the streamer but when im on android samsung the volume increase is too big. Can this be changed into smaller steps?
Hello
What are you streaming / how?
The change using the remote / android volume buttons seems to depend on the what / how.
Or try using the wiim app and tap on the left / right of the volume slider to change by 1.
Im streaming spotify on android through my. Samsung phone. Yes ive seen that through the wiim amp it goes by 1. Was hoping to do it with my phone buttons.
Here's some testing I did a while ago
Seems like something they should be able to fix and let it depend on the wiim app instead of the app youre playing on
Yeah, using the Volume Limit within Audio Settings will affect the absolute volume level changes, but not help with OCD for non 1 step changes ;)
Not so sure about that. It's up to the phones operating system in the end.
What is the typical volume range you are using? What output are you using and into what other devices?
