vTuner vtuner replacement
KHAGENA
Topic vtuner replacement:
There is a project “YTuner - coffeegreg” on github where you can easily create your own vtuner replacement at home, for example on a Raspberry Pi. You can save your own station URL in a separate file and play the stations from “RadioBrowser”. You can also set up a DLNA server (miniDLNA) on the Raspberry Pi at the same time where you can store your own music files (I currently have around 40,000 music tracks stored). Both YTuner and MiniDLNA on a Raspberry Pi work great with the “WiiM Ultra”. That's why you shouldn't remove the vtuner function from the firmware for "WiiM Ultra".
https://github.com/coffeegreg/YTuner
