I have been using the WiiM Mini for sometime now but recently purchased the Ultra. My current amp, the Cambridge Audio axa35, only has analog inputs so I was using a 3.5 mm to rca cable. I thought the Ultra sounds really good using the unit’s DAC. But for comparison, I hooked the Mini back up. But there was no audio coming from the right channel. I checked and double checked all settings and connections and tried different inputs on my amp but nothing helped. I also tried another 3.5 mm cable I had but still no audio from the right channel. I still have my Chromecast Audio streamer so I connected it in place of the Mini. Still no sound from the right channel! I am at a total as to why this is happening. The only difference between the three streamers connection wise is that the Mini and Chromecast Audio use a 3.5mm to rca cable, but the Ultra uses rca to rca cables. I’m wondering if anyone has any idea as to why this is happening. I’m stumped. I’m going to hook up my other amp with a toslink and connect that to the Mini and see what happens.
