Spuddywuddy
- May 5, 2023
When I use a coax cable, approximately every 5 minutes I get a 1-2 second hiccup/stutter. It is very annoying. It also does not matter what source I use. I happens with Tidal, Spotify, Soundcloud, Radio Paradise or local files. This does not happen when I use a optical cable.
Things I have tried are: Using a different coax cable, lowering the output setting in the Wiim app, Resetting the device and trying a different DAC. I'm using 5ghz wifi and the signal is 'Very good'. Any help would be appreciated.
