- Sep 23, 2024
Explore our latest tutorials and guides, designed to enhance your audio journey and unlock new features. Here are all the big new articles and updated articles on our help center from January.
Would you like any further adjustments?
App/Software Usage
- How to Stream Apple Music to Your WiiM Devices: Stream your favorite music from Apple Music directly to WiiM devices via Bluetooth, AirPlay, or Google Cast.
- How to Stream YouTube Music to Your WiiM Devices: For YouTube Music users, stream directly to WiiM devices via Bluetooth, AirPlay, or Google Cast.
Device Features & Audio Optimization
- How to Create a 5.1 Surround Sound Experience with Multiple WiiM Devices: Learn how to create an immersive 5.1 surround sound system using the WiiM Amp Pro and WiiM Ultra, which support Dolby Digital Audio. By connecting multiple WiiM devices in a multi-room configuration, you can enjoy a cost-effective and flexible setup ideal for movies, gaming, and music.
- How to Set Up Bit-Perfect Playback on WiiM Devices: Bit-perfect playback ensures that the audio signal is transmitted from the source to your output device without any modifications, maintaining the original quality of the sound.
- General Guide to Setting Digital Audio Output to PCM for Various TV Brands: Certain WiiM devices, including the WiiM Mini, WiiM Pro, WiiM Pro Plus, and WiiM Amp, support digital audio input in stereo PCM format. When connecting these devices to your TV via the Optical In or HDMI ARC interface, follow the general instructions outlined in this guide to configure your TV’s audio output to PCM.
- Using the Group Audio Delay Setting for WiiM Multi-Room Audio: The Group Audio Delay setting is specifically designed for grouped playback in WiiM multi-room audio setups. It allows you to adjust audio delay for grouped devices to address audio-video synchronization (lip-sync) issues with TV inputs and improve multi-channel playback stability.
Dive Deeper Into WiiM Technology
- How to Connect Your WiiM Device to a Mobile Hotspot: If your home network is unavailable, you can set up a mobile hotspot to keep your WiiM device connected and running smoothly. This guide provides clear instructions to help you connect your WiiM device to a mobile hotspot effortlessly.
Troubleshooting
- Troubleshooting No Sound Issues with HDMI TV Input on WiiM Devices: Need a hand troubleshooting audio issues from a TV to your WiiM device?
- Troubleshooting USB Disk Playback Issues on WiiM Devices: Some troubleshooting guides for common issues encountered with using USB drives with WiiM devices.
User Manual
We’ve updated user manuals for the following products: WiiM Amp Pro, WiiM Amp, WiiM Ultra.Have Questions or Suggestions?
We're here to help! Share your thoughts, ask questions or suggest new topics below.Would you like any further adjustments?
