ckishapppy
- Apr 7, 2024
Hi, I started to use the Wiim API with node-red (mainly with HomeKit). What are the commands to get the status of the Audio Outputs and to set the Audio Output? I want to set a couple of different Airplay 2 devices receivers depending per daytime (without opening the Wiim app) or ensure that the default Airplay Receiver is selected from all available choices at home (also without opening the Wiim app)...Pls advise.....
		 This functionality existed in a previous firmware version, but was apparently removed, which is a pity.
