Hi all,
I aplogize first for my bad english...
I've bought a Wiim Pro Plus and since the beginning I have problems with SPDIF out.
The Wiim Pro Plus is plugged to 2 Devialet Phantom II.
Sources: Qobuz (Ethernet) or TV (SPDIF in).
The SPDIF output resulution is set to 24/96 (max for Devialet). Fixed volume. No EQ.
Everything is always OK for 30 to 60 minutes, but each time after the delay, sound is going to be bad, it crakles, with less power.
I just need to reload the source and it's OK but don't understand why?
I try with 3 optical cables....
No problem in analog, with RCA output to the Devialet (but by this way I don't use the Devialet's DAC).
Any idea?? Hardware problem? Should I return the WiiM???
