A Angelos58 Major Contributor Joined May 13, 2024 Messages 69 May 23, 2024 #1 Hi everyone, Is there a way to setting the volume of right and left channel separately? Only volume, db, for all frequencyes. Thank you
Brantome Moderator Joined Oct 20, 2022 Messages 6,188 Location Scotland, UK May 23, 2024 #2 There’s a balance control in the device’s audio settings which in effect achieves that.
A Angelos58 Major Contributor Joined May 13, 2024 Messages 69 May 23, 2024 #3 Thank you very much. But the Balance control is the same that setting each channel volume? I'm not sure. Help me to understanding.
A alpha_zulu Major Contributor Joined Jan 16, 2024 Messages 134 Location Germany May 23, 2024 #4 Yes it is the same.
A Angelos58 Major Contributor Joined May 13, 2024 Messages 69 May 23, 2024 #5 alpha_zulu said: Yes it is the same. Click to expand... I'll try.
