WiiM pro plus vrms question
Claudius
I'm using a Pro Plus analog output to a Naim Nac 62 preamp. Line input on this preamp is rated at 75mV, 47k ohms. I wonder if I should change WiiM's output level set by default at 2vrms?
weird... it seems to me that it would be more typically a 750mv or 0.775v, 75mv is an error? :censored:... but clearly, use the fixed 800mv or 500mv output of the wiim... observe the level where you navigate at the potentiometer... prefer a rated level wiim or not at the start of the track, this is the place where the potentiometers of this type are the least balanced
