Witterings
Senior Member
- Nov 1, 2022
I'm trying to use the Line In on a Pro Plus in an HT Bypass setup but the output from my AVR seems quite low and if I turn my endpoint amp up to full volume, my AVR is still having to compensate with approx +6 which probably means it's introducing distortion but also if I forget to change the volume and plug something else into it's likely to blow something.
The Line Out level on the WiiM is set to 2 Vrms which I guess is the loudest ? and volume limit to 100% and the volume slider for line in set to full.
