Wiim Pro vs Pro plus vs Ultra for streaming only
venkyrenga
I currently have a Wiim Pro with Allo Shanti low noise power supply and using it only as a streamer. I have an external dac.
In my case is it worth upgrading to Pro plus or Ultra for a better sound quality?
Thanks in advance.
If you connect to an external DAC Pro and ProPlus are the same thing.
With Ultra you gain the USB port (better connection to DAC imho), but you lose AirPlay. So it depends.
That is exactly what I thought but this article had me thinking.
"But there’s more to it than just the DAC chip. The clearer attack and low noise of the WiiM Pro Plus also come down to a more sophisticated clocking circuit and power supply. This has been improved over the standard WiiM Pro model and makes a noticeable difference."
That is only relevant if you use the internal DAC.
Improved clocking can maybe be measured as lower jitter but cannot be heard.
The power supply has no influence on the digital part at all. That is also the case with the WiiM Pro. No need for any special power supply.
hgo58 is right, not a factor if you use digital out
Also, you didn't specify which DAC you are using, the one in the Ultra is pretty good, probably better than a lot of budget DACs out there.
I have an Eversolo Z8 which by itself is more than double the price of the Ultra. I compared the two, Z8 is better but not by much, had me consider if the external DAC in my system was redundant.
I am using the DAC in Audiolab 9000a amplifier.
If implemented properly the ES9038Pro in the Audiolab should be a bit better than the ES9038Q2M in the WiiM Ultra.
If you can hear the difference, I don't know?
So I would stay with the setup you have for now.
The Ultra with the rumored new fitting power amp could however be a low cost alternative?
