Tried hard drive to Ultra. Scan did not pick up all my library. Most albums had one or two songs on them only.
Can i use the WiiM Ultra as a DDC between my PC and my tube Dac and that sound superior than my pc->chinese usb to coax converter->tube dac.
The tube dac is a cd redbook resolution only. Which clock would it use in this set up?
Toslink is the only way? My HP all in one does not have toslink out. Only usb. Does this mean i would require 2 DDCs? One for usb to toslink and then wiiim ultra coax out to tube dac? Is that better or worse for the chain?
Can i not just use a usb adapter on the WiiM?
Another question: My thinking is having the sub connected to the WiiM instead of my tube preamp so i can always use it for room correction on 100-200hz and below for both movie playback as well as my music from PC playback, but at that point it won't be a bit-perfect signal coax out to my tube dac? No point in having a non oversampling dac at that point?
