WiiM Ultra Bluetooth Subwoofer can’t connect.
Stoneguy
how do I connect my Bluetooth sub woofer to my WiiM Ultra? My other speakers are running through my amp but cannot connect t directly for the sub.
Thank you for the link.
I also found that SVS makes a receiver/transmitter specifically for a subwoofer to integrate into wired speaker system (South Path Tri-Band audio adapter). Quite pricey $199.00 but supposed to work very well and designed for a bluetooth sub. Might try the less expensive method first as I already have 1 bluetooth transmitter/receiver and just buy another one to hook on the subwoofer.
Thank you again.
