I really enjoy the sound quality of my Wiim Ultra – I'm using it with Klipsch RP-8000F II and Kenwood KA-990, and it sounds great. But I have one big problem: I can't select USB input from the device screen. I need to use the phone app for that.
I wanted to use Wiim Ultra without a smartphone, just play FLAC files from a USB stick. But right now it's not possible. This is a big limitation and makes the device less useful for me.
Will you add USB input selection on the device screen in a future update? It would help a lot.
Thank you,
Thank you,
